I have been trying to set up a NAS at home for creating backups from my DVDs and a couple of Blu Rays (i'm hoping to add a few more as they become affordable) and then play them through a PC from elsewhere. I have had the bad experience of losing some CDs and DVDs earlier to scratches :-(
For Blu Rays, is the following setup good enough to get the best backup?
1. An external Blu Ray drive off my PC's USB port
2. Software like PowerDVD
If there are other ideas, let me know.
Which ever way you choose to rip a Bluray, AACS and BD+ encryption follows. Ripping a bluray can involve multiple steps depending on the way you want to copy the disc, like for example, you want the entire disc to be copied with full menu navigation support and no A/V loss. OR you want to copy just the movie file with no menus and extras to save space, but keeping the A/V quality intact. OR you want menus and extras but can compromise on the A/V quality....etc etc. Usually with ever decreasing price for storage, people prefer to copy/rip the entire disc with full menu navigation and no A/V quality loss.
For that the easiest and the fastest way is to rip the disc in
ISO format. ISO format is easy to play on a PC and almost all the media players also have started supporting it with full/light menu navigation. But as I said, ripping a disc also brings the AACS and BD+ encryption along with it and we need to first get rid of it in order to play the disc on a media player or PC.
AnyDVD HD comes in to the ptcture here. Get the application and run it in the background that would remove the copy protection.(all automated) Then use any burning tool (I prefer
Ashampoo Burning Software) to rip the disc in ISO format on your HDD.
Now to play it on your PC with full menu and all, you dont have to burn it on an empty BR disc. Get any
Virtual CD application (I prefer
Virtual CD v10) like
ALCOHOL or DEMON Tools or which I prefer,, Virtual CD. Virtual CD creates virtual discs on you PC which behaves very much like an actual drive. Just insert the ISO image in to the virtual drive and play it using any DVD playing S/W like Power DVD or VLC or Win DVD ...etc with full menu navigation and no quality loss. Playing through Media players is even easy. Just copy the ISO to an ext HDD, plug it in your media player and start playing the movie, again with full/(or light menu navigation depending on the media player) with no quality loss ........
Hope this helped ...
Sammy
