Very true ! i should have added the statement i usually make as well..<snip>
I genuinely believe that a Rs 20K to Rs 30K CD Player will FAR Outstrip the playback quality of a TT + Cartridge + Phono stage costing a similar amount.
Infact a Rs 20K CD Player will outstrip Rs 50K worth of vinyl playback ....
Each new Vinyl Disc will cost you Rs 2,000 !!! How much music will you be able to afford ? 10 LPs ? 20 LPs ? How long will they keep you entertained ?
Since you are on a Tight budget, I think your money will be far better spent on a CD Player. Infact you can save substantially when buying a CD Player (compared to Vinyl) and divert that money towards better Amp & Speakers.
If you do buy a CD Player with a USB Input, It will (along with any existing Laptop / computer for shared Audio duties) open up an infinitely large world of available music ... either streamed or CD Rips and downloads.
It is not my intention to HiJak this thread , and yes, I do Love Vinyl Playback, but IMO its not value at the entry level.
Vinyl is a great option if
1. you already have a lot of vinyls which you might have got.
2. you listen to music from 80s or earlier
3. you have the budget to invest in decent quality vinyls at 1500+..till 3K per copy and you know which are the good recordings !
4. you want to be hipster cool..in that case your vinyl player is just an additional option with limited albums but you will listen to majority of music streaming etc
+1 to what @IndianEars has mentioned.
