Rupam
My Belkin Economy Series 4 Socket surge protector was blown yesterday. Partly it was my fault. I normally use all my equipment in surge protector and the surge protector mains cord is plugged in a wall socket.
I don't put AV on inverter back up because my inverter is not powerful enough to take the whole load. Yesterday, I mistakenly plugged in my belkin in the inverter line socket and my rotten luck, just after 5 min the power cut, triggering the inverter on.
I disconnected my system as soon as possible. But then when the power came back, I found out that Belkin surge protector is not working and If I plug it in the wall socket, the circuit breaker trips.
Are these so called Reputed brands make these surge protector so flimsy that they are blown in such ordinary circumstances? Then, what will happen if lightning strucks or there is a real current surge ?
I'm not willing to take this piece of shit to service centre which is 40 km away and waste my time.
Can you guys please tell me which surge protector should I go for? What are you using?
