Thanks vinod I'll check
Ok mate, im going to search that shop on wednesdayPlease do let me know if you come across this shop. i also want some special size flat belts for some Turntables
Already checked with anmol but they dont have that size what r im looking, navabharath have lots of belts but there also same dont have my require size beltdo check with Anmol Electornics or around this shop,also keltron (no sure if the shop name is correct )
I had taken few belt for CD drive mechanism about 2 months back, had seen 1 inch to 4-5 inch diameter belts with him. but these are 1-2mm square belts,2-4mm flat belts.
Nice one, if you locate the shop, kindly let us know as well. Looking for a replacement belt for JK_Chaos' Pioneer turntable. Not available anywhere in Trivandrum.
