Best 2 channel power amp to connect to my AVR
gowmara
Coimbatore
I have Marantz nr1608 , I need to improve stereo performance (front speaker) by adding external power amp. Please suggest good cheap 2 channel power amp
How cheap? can you put a number? Also what speakers are you using it with?
Best, good, cheap all don't gel well in the same sentence. You can get either or. A decent power amp, 2 channel will be more expensive than your NR1608. Except the crown. Which is cheap.
Do try to audition it with the same speakers. Make sure there is no 'hiss' coming from the tweeter..
Emotiva A-100 should cost you 23K odd.. 30K is net price for the slightly bigger A-150.
Dali Zensor 3 is a low sensitive Speaker. Marantz NR1608 itself would drive it well. Did you check the input source level. Also I would suggest good towers instead of a poweramp for Zensor 3.
