Hi Samuel,
Can i go for Onkyo 5105 ?
Oh Yes Razaa you can very well go for the 5105.
In that what is pre out sub woofer?.. what is the diff of sub woofer out / pre out. Whether i can get good quality music there?
A Subwoofer out is also known as LFE out (Low Frequency Effects output).
Typically frequencies below 150Hz are sent by the receiver through this jack.
DD5.1 and DTS have dedicated LFE channel encoded.So when the receiver detects the signal it'll automatically send the signal to the sub out or LFE out. So if you have an Active Subwoofer connected (Subwoofer with built-in Amp), it'll produce all the bass effects sent thru the LFE channel.If you switch it off all the bass will be redirected to the main speakers.
My requirement is my sound card (computer) have RCA 5.1 out. My games is having Optical out
You have both the options in Onkyo (Analog 5.1in + Optical in + Digital Co-axial in) and You also have HDMI (
High
Definition
Media
Interface) pass through.
There are converters available but I personally don't recommend them.
Moreover a good cable converter will set you back by a couple of thousands.
I can't comment on Philips as I've not heard it.
But the Onkyo 5105 has a true AV Receiver.You can easily add better speakers in the near future and take the sound quality to the next level.
:licklips:
My requirements are fullfilled in Sony 390K (new) models and in Onkyo 5105. But from this froum i came to known this two system is not good for music.
What sounds good to you means the most.And what does "good sound" mean...you need to audition,Everything that you shortlist.
And pick the best one.
And finally a word , HTiB(Home Theatre in a Box) are generally tuned more for Movie performance than Music reproduction.
The satellite speakers which comes with the package are often and in most cases are tuned for movies.Their frequency response falls sharply in the lower mid bass and bass region.Even some well known Hitb speakers struggle to produce 100hz with authority and without booming.
But this is where the subwoofer comes to the rescue.The subwoofer provides the low frequency grip that the satellites seriously requires.
So overall adding a quality Bass Foundation in any system or setup will add to the quality of the sound reproduced.
So again the 5105's receiver is a capable receiver which can handle much better speakers.So you need not have any doubt regarding that.
Finally it all comes down to money.I say for the price this system is loaded.
There are options from Denon & Yamaha but I don't know about them. I don't know whether they offer the features available in 5105 though the denon will sound good with music and most agree.
So there you go Razaa , take a serious look at the 5105.I think I've not bored anyone with my long post.
Thanks for reading.Do a good audition over the weekend and decide.
Kindly excuse if you feel I'm biased.Yes I'm biased towards Sound Quality,Feature's and last but not the least Value for Money.
Let's wait & see what other friends are suggesting.
Till then Happy AV hunting.
with best wishes,
Samuel
