I have set up a speaker+amp+dac setup in my living room that I want my family to be able to connect to with their respective mobiles and WiFi stream Tidal to a device that then sends the digital signal to the optical or coaxial in of my high quality dac.
Please recommend the simplest plug and play streamer type device solution. The PW Link seems to do what I want. Does anyone have pointers where to buy it from in India?
I don't really want its room correction ability (my room has good acoustics) nor do I want to use the dac of the streamer since I am using a high end dac. Is there some other device besides the PW Link? All I really need is a streamer + optical out that is still simple to use out of the box and has a robust android app that works reliably.
I am not interested in fiddling around with raspberry pi based DIY or other devices that are not plug and play.
