Best way to play music from mobile to AV Receiver
No need to spend money on any android box or streamer like Wiim.
As I was contemplating to buy wiim, nobody had the concrete answer what difference it’s going to make in the SQ, as mentioned by all, if both the devices are on the same network, then you can play directly from your phone which is then streamed to AVR. I always use spotify connect and I am so happy with the SQ as well.
