Best way to play Tidal Hi-Fi Master on my Home Theatre System
rajivaryan1984
INDIA
Hi Folks, I am using VPN and subscribed to Tidal Hi-Fi / Master on my PC currently.
Is there a way or any DAC I can stream or connect to hear same Tidal Hi-Fi / Master on my HT setup (Denon X6700 H).
Kindly advise..
RK
The tidal app on your pc unfolds mqa partially. If you want full unfolding you can connect it with a mqa enabled dac like ifi zen dac. Depends on your budget actually.
Kindly advise..
RK
Don’t get into this rabbit hole,
Your Denon would play Tidal Hifi from HEOs app directly. No need for PC or a DAC.
some say MQA is a gimmick, I have used MQA dacs and Non MQA dacs too, to be honest it comes down to way the DAC is implemented and sounds.
Also last I heard from someone was MQA is going bankrupt. Not sure how true.
Enjoy 🎶
