Blu Ray Camcorders & 1080 Lines/Pixels.
deba
Kolkata
Dear All,
Found the following link for Hitachi Blu Ray Camcorders:
Camcorder : AV Products : HITACHI
Any other info/ specs / prices on Blu Ray Camcorders can be posted for information.
What is the difference between 1080 Lines and 1080 pixels resolution. Are they same ?
What is the difference between "Line" and "Pixel" - Are they same , Kindly define.
Scan line is one line, or row of lines, in a video line produced on a cathode ray tube (CRT). Scan lines are important in representations of image data, but in true technical terms these dots are different from the modern day pixels. The display becomes more clear when there are more colored lines per inch. The number of colored line per inch is directly proportional to the resolution.
Pixel is the smallest discrete component of an image or picture on a CRT screen, greater the number of pixels per inch the greater the resolution
PAL CRT television has a total of 525 horizontal scan lines, it only uses about 480 of these for the actual image. There are 720 pixels in each interlaced scan line this forms the image.
HDTV can resolve finer details and hold smoother curves. Plus, you get considerably more pixels to look at HDTV has a total of 1,125 scan lines, but it only uses 1,080 of these for the actual image There are 1,920 pixels in each interlaced scan line.
Anil
MY DIY PAGE
