Dear All,
Most of the Blu Ray players purchased from USA (may be via 20North) has its input voltage fixed at 110 V for which you will need a step down transformer but the Input Cycles is fixed at 60Hz whereas in India its 50Hz.
How do you address the problem of Cycles because the speed of the Motor should also change - Kindly discuss and guide.
