Blue Tooth adapter & a pre amp for a LP player
audio funk
Gurgaon
Looking for advice...
I wanted to hook up my amplifier (it's an old Yamaha ) to a Bluetooth adapter. Most sites seem to recommend the Logitech adapter which you can purchase off most sites at about Rs. 1200. However some reviews talked about lower frequencies being lost.... . Any experience on this or are there Any other serious contenders even if the cost quadruples?
I also have an audio technica LP player and looking to upgrade my preamp Which is pretty basic. The preamp connects to my Yamaha as well. Would a budget of 10k be sufficient ?
Thanks for any advice!
FWIW I have the Logitech Bluetooth adapter. It works very well. I have not noticed any loss in the lower frequencies, but then I am not actively looking for imperfections. For all practical intents and purposes it is very good for streaming music wireless-ly.
