>Spkr ordered on Hifimart : Boston Acoustics A26
>CDP on hand : entry level philips DVD/DVP3356 which has a coax out
>Typical CDs played : Mostly Indian pressed carnatic,hindi and Western music CDs available in India (mostly instrumental fusion )
>Amp on hand : Lepai 2020A+
>DAC on hand : Behringer UCA202
***Amp under consideration : PM Series ** (NAD,CA,Rotel not under consideration this time )
PM6004 : No Digital inputs (within budget)
PM6005 : Digital inputs but no USB B interface (within budget)
PM7005 : Has all digital inputs (but way above budget)
1. Does using the coax out really make a audible difference instead of using tradiotional RCAs for for the kind of source playout indicated.
2. Which setup offers better sound :
a)In case i go in for the PM6005 : Connection mode : PC to UCA202 to amp optical input may work
b)In case there is a possibility to go in for PM7005 : Connection mode is simple. PC to Amp USB B .Will this sound audibly better given that i may stick to A26 spkrs only.
3.May consider upgrading the CDP . Any suggestions from forum experts is welcome (entry level CDP only)
Thanks in advance and appreciate your time taken to respond.
