BR Disc for testing HT effects
gman
chennai, India
Hi all,
Been searching all over for any BR discs that have multiple clippings to test different types of effects from various movies...couldn't find much. Looking for a proper legal source (i.e. torrents etc. wont help in this case) . Any way out??
Hi all,
Check this link for all sorts of trailers.
Else, you can use this DTS test disc.
After copying them to a pen drive, Would I be able to test using the pen drive or should I write it to a disk? pls advice.
Yes, you can play'em using pen drive, no need to burn a disc.
Try Dolby sound demos i have tested my HT with it Dolby/DTS/THX Trailers | Movies - Digital Digest might help
Thanks a bunch!! I had downloaded some from youtube earlier but noticed youtube doesnt support 5.1 so the effects were not routed to the correct speakers. I will revert once i download from these sites and have a play. Thank you once again!! I am sure this will hep quite a few folks like me out there.
