Hi Guys,
I am new to this forum and got to know about it from YouTube comments section.
Planning to buy 4K LED TV by end of Jan 2021.
Primary usage will be for PC & PS3 monitor and OTT Content... No DTH usage.
Most Probably will use this for 5 yrs and then upgrade to 55” or above.
Requirements:
Budget: Under ₹35k
Display: 4K (Good Colour Management)
WiFi: Dual Band (if not, Ethernet ports will suffice? Using Airtel 200 mbps)
OS: Android or any other but should support Chromecast internally as I am using iOS.
Service/Warranty - A good one or atleast a manageable one.
My list as follows:
Requirements:
Budget: Under ₹35k
My list as follows:
- LG 43UM7290PTF - ₹ 35k (OS - LG & not android pie/dual band (I guess)) and a good service. Has Apple airplay support as well.
- HiSense A71F - ₹ 27.5k (OS - Android/Dual Band).. Based on ownership reviews service is not good.
- Haier LE43K6600UGA - ₹32k (OS - Android/Dual Band)... Not sure how the service is.
- VU Premium 43PM - ₹27k (OS - Android/Dual Band).. Not sure how the service is.
