viralbug
Hi everyone!
I'm looking for a 5.1 setup for my room. My budget is pretty limited at 30-35k. It will be used for 50% music/50% movies and connected to my computer. Room size is 13x10 and listening distance is 1.5 feet when listening to music and 8 feet when watching movies. I need DTS-HDMA decoding and 4K support from the AVR.
This is the setup I was considering:
Pioneer VSX-329
Pioneer BS22 for fronts
BA XS satellites for rear surrounds (will be bought later)
Pioneer C22 center speaker (will be bought later)
Will consider a subwoofer later if and when required.
I was considering the Yamaha YHT-299, but it doesn't support 4K.
Other AVR options like Yamaha 477 are over my budget.
What are the grey market options in Mumbai/Navi Mumbai and are they advisable to go for?
Right now I'm looking at BS22 bookshelves and a decent AVR to go with it. The Pioneer VSX-329 seems to meet my requirements since I don't need anything extra.
Am I making the right choice of going with BS22 bookshelves if I would be listening to music at such close distance? Also these are back ported speakers and I have limited space on my computer table which means they will be placed very close to the wall.
Earlier I was thinking of cheap 5.1 speaker systems, but decided to increase my budget and go for separates for the long run. However, the bookshelves size requirement is something I am confused with.
Kindly help a confused soul in choosing the right components.
Pioneer VSX-329
