Budget 5.1 Surround Sound System for TV Viewing
ksature
Mumbai, Maharashtra
Hey.......
I am planning to buy Micromax 40" LED TV for my 9X9 ft room, with the big screen TV I am planning to install a "BUDGET 5.1 Surround Sound System".
I have spent on the LED already that's why I wont afford spending a lot of money on the audio system, and my budget is limited to 10K only. It will be increased on extreme conditions :lol::lol:
I did googling and decided to go with:-
1. F&D D1061 Home Audio Speaker (5.1 Channel)
2. Sony DAV-TZ145 5.1 Home Theater System
(With DVD Player)
If any other option is available, would like to explore that to
Following are some points which I would like to clear :-
1. The LED I am purchasing don't have Dolby Digital Audio System rather it has SRS Sound
System installed with 5 Band Equiliser! Will it be able to make 5.1 Surround Sound? If not any solution.
2. If the TV emits 2 channel sound, can it be converted into 5.1 Surround Sound using a
receiver?
3. Are component connections mandatory for getting such a surround sound? or just AV cable
will do the needful?
4. My most important query is, if I connect a simple Sub-woofer and 5 speakers system (F&D D1061 Home Audio Speaker (5.1 Channel)as mentioned above), will it produce surround sound or it is mandatory for me to have a amplifier or receiver (like Sony DAV-TZ145 5.1 Home Theater System from my option)?
Hoping for your guidance..... thanking all in anticipation
