Hi Team,
Hope you are doing good. I have Yamaha YHT-299[ AVR in it is HTR-3066] from 2014 that I used less often. Now I plan to move it to other smaller room so that it can be used more frequently.
Before that I want to upgrade the fronts as I feel the stock speakers lack details. So this will be used for music and movies(Have Sony Blu-Ray player too), and will connect FireStick.
I have limited budget, I was thinking of Micca mb42x that was available on amazon for like 9K. Its not available anymore. So I have decided to increase my budget till 21-22K max. I have shortlisted the below ones:
1>JBL Stage A120 ( A130 has rave reviews but not available, I checked with HiFiMart.
2>Mission MX1 seems in my budget too.
3>Mission LX1-MK2
4>Q Acoustics 3010i , on some sites it was for 21K.
5> Pls suggest any other
Also, will the above speakers be compatible with my AVR? I like a bit treble oriented detailed sound (Due to my AudioTechnica M50x and Fiio F9 Pro IEMs).
Also any links to buy will help.
3>Mission LX1-MK2
