Budget Home Theater- Novice
hannibal09
Navi Mumbai
Come across this offer at Hifimart
Wharfedale DX-2 Home Cinema Package with Denon 550BT AV Receiver for 80k
Is this better than HTib from yamaha & onkyo.
Also is this set compatible since speaker power is rated max 100w whereas peak output from avr will be 130 watt
If any other suggestion, then let me know. Budget is strictly 80k max for now. May upgrade in a year or two. Uses mostly be Movies, Games and 30% music.
Sounds like a decent deal, a single no hassle all in one package! Not sure, never heard any of these ever, but see if you can get a discount from HFM.
A suggestion though, if you are planning to upgrade in a year or 2, why not get a pair of bookshelves and a decent enough AVR (you might be able to get really decent ones for less than 80), and slowly add things to it, they might both last you for more than a couple years and you can perhaps have a nice system over the next couple years in maybe a little more money? You can add sub, then rears and finally center from the used section here.
