elangoas
Yes, the text is clear enough to read from 10 feet distance.
The speakers system is 4.1 and not a surround sound. (Sony SA-D10)
So, we have kept them all in the front.
I definitely agree, this is just a basic setup, but works well - for now
Any suggestions?
Ok fine.. Nope.. At best you can re-use the satellite as surrounds & suuround back when you upgrade to AVR..
Yes, the diagonal screen size is about 110 inches![]()
Great..
Sure, I would also suggest you to try and re-position the PJ to get the best possible projection clarity.
Yes.. Will do them in sometime & share pics here..
I am looking forward to mod the screen - to make it brighter & clearer. Perhaps a grey paint to begin with
Do you mean painting the vinyl screen?
Hope you have seen Black diamond screen videos.. Try to get close to that thru experimentation.. There are handful of DIY black screen with paint videos - https://www.youtube.com/watch?v=MssmLgmMwtA
