rdksrk2013
Hi All,
I am new to starting a thread but have been religiously following this space for the past 6 months. I understand that lot of threads were started but I believe each HT can be build in a different way and forum members will get lot of ideas to benefit and share with these efforts.
I had this obsession to make my own HT. My house is under construction and has room on the terrace which I am planning to have a dedicated HT.
Bare room is almost complete(Snaps attached) and I had decided to start preparing for starting work on the HT. I thought of starting a dedicated thread and inviting from everyone their suggestions for making a simple Home Theatre.
At the start I would like to make clear the following:
1. Am not seeking a perfect Home theatre. Just make a decent good looking HT with a bit of acoustic work thrown in.
2. I am not a audiophile
3. Keep the budget as simple as possible within the constraints which I have eg: dimensions, budget etc.,. I know it is impossible ! more we go deep into details, more we keep spending.
4. No specific budget in mind but resources are not unlimited ie limited availability of resources ( almost drained money in building the house itself!!). I think 2 lakhs is what I am foreseeing.
5. As usual I am a technical person and like everyone has only the weekends to spend on this hobby. Planning to Keep busy with this hobby as a diversion from work pressures .
6. Till date did not purchase any equipment for HT. Exception is I have a set of monitor speakers(8 Ohms) which are more than 15 years old used in a Dolby Pro-logic HT using a VCR at that time. These are in good condition(packed) and I am planning to use these as surrounds.
With the limited knowledge I have, I had listed below the sequence of the components to purchase:
1. Projector ceiling mount
2. Power cable, HDMI cable & speaker cables
3. AVR
4. Speakers
5. Acoustic material
6. Audio rack
7. Projector
8. UPS
9. Screen
10. BDP/Media player
I am planning to purchase in the above sequence.
Attached below is the sketch of the proposed room layout. I have the following questions:
1. How much far should I get the ceiling mount fitted from the screen?
2. How much far from the backside wall/window(in this case) should the ceiling mount be placed?
3. What will be size of the screen for this distance?
I am planning to select a projector with lens shift.
Thanking in advance for advise from everyone.
3. AVR
4. Speakers
6. Audio rack
7. Projector
8. UPS
9. Screen
