DruShra
Hi everybody. I am part of this wonderful forum. Also watching home theatre threads. Now I am also in the process of building my home theatre audio. I have plasma TV. There are couple of options with me kindly guide me here.
OPTION 1. To get a good receiver like yamaha 3067 pioneer or denon which supports Dolby true HD Dts Ma Aux in etc. Pair with Polk audio RM 6750 or wharfedale movies 70 or BA s 5.1 or Yamaha. Budget 50-60k.
OPTION 2. I have old 4 Sony speakers of component system 2 front 3 way and 2 surround one way. Get any of the above AVR and pair them with these Sony speakers initially and then add centre and sub if required if Sony speakers pairs without much hiccups. The front speakers has impedance of 8 ohms and can take 8 to 16 ohms as per specifications, the surround one way has impedance of 16 ohms. The component system was 90+90 RMS continuous power.
OPTION 3. I have 5.1 Altec Lansing entry level pc speakers attached to pc. But 7 year old pc is giving lot of problems now so I am using my old dell laptop and pc speakers are lying almost unused. can I connect it with DAC? DAC generally has 6 rc out ports 2 each for front and surround and one each for centre and sub. However my pc speakers Subwoofer has 3 input that is for front, surround and 3rd for centre and sub. And there are 5 out clip type connections each for fr fl Sr sl and centre. These speakers are sufficient for my 9x10 bedroom but may not be sufficient for 9x18 living room.
Now please help me build my home theatre system. I want to go with option 2 first. If the Sony speakers don't give me good result then I may switch to option 1.
A friend of mine is going to Singapore within few days. I can ask him to bring AVR for me. Or should I ask him to get 2 bookshelf and purchase other sprakers here if option 1 is only suitable.
Thanks Sanjay.
Thanks Sanjay.
