manish26264
have you connected the spdif from the spundcard/onboard to the spdif of the ATI2600?
NO :sad:
is it there on the cards, and which type of connector is to be used?
NO :sad:
NO :sad:
see if this link helps....
Spdifer | AC3Filter
also search for HDMI_R168.exe the realtek ATI HDMI drivers and see some new settings inthe ATI control panel for spdif output.
Most graphics card advertise as 5.1 capable via spdif but the only working stuff I have personally seen is the onboad nvidia 8300/8200/9400 which output 5.1/7.1 from HDMI.
But 2600 also works - just need additional SW to make it work I guess. Search and go through trials - you will set it up.
Also use the latest ffdshow through MPC-HC - pass AC3/DTS through spdif. See if it works. Its difficult to offer a solution without seeing the problem but i guess the above drivers and SW can fix it.
2 things.....
hope you have used 96 hz in optical out in spdif (check with playing with MPC-HC ffdshow enabled as filter in audio and let ac3, dts passthrough). If 5.1 is passing through then sw setup is fine.
in the audio hw section od XBMC there is an option of digital receiver and pass through for ac3 dts and also disable stereo output for all speakers. It works fine man, Just try again. (let XBMC downoad all fanrt images for movies, music etc and see you collection shine with stories, images, movie info, ratings etc).
PS: I did not get the 5.1 cable repair part. Anything decent band bridge is fine.
How to check MPC-HC ffdshow enabled as filter in audio ?
HTPC without bray will be fine.But playing HD content ,you need either powerful processor(>C2D2.4 Ghz or P4 3Ghz) or GC (HD series)
Even with GC processor shld be atleast C2D 2.4Ghz(dont know abt AMD)
may be wrong assumption... laptop with 1.66GHz c2D processor,1GB ram...with inbuilt intel GMA plays HD 720p easily
This is something I have been pointing out for a long time now. It is absolutely not necessary for a HTPC to have a dedicated display card. It can play all sorts of video content (yes, HD too) just fine even without a display card.
on 15.5 inch lappy sceen the inbuilt GMA displays fine ....
but with dedicated Graphics Card ,on a bigger screen like 42 inch plasma ,difference in video quality may apparent.....
i have never built HTPC but HTPC builders use G. Cards suprateep what ur experience say?
For all the people who are using HTPC's here are missing the basic idea behind HTPC. An HTPC is Silent/Low Profile / Beautifull Looking living room PC.
Please suggest/choose components which produce very low noise. Things like using > 80% efficient psu , 2.5" Hard Drives or even SSD's, passive cooloers for Components go a long way in separating an HTPC from a PC.
Additionally, use specialized cases which are meant to merge in with your equipment, No they are not as costly as one thinks.
Besides that use an interface which can give you 8-10 feet experience without using a KB or Mouse.
Lets not make this a general PC configuration thread.
I beg to differ. IMHO, the basic idea behind a HTPC is to have a PC which performs at the levels necessary for an ideal Home Theatre setup, be it a large screen TV or Projectotor.
It has to be silent, be capable of huge storage, process high definition video & audio without hiccups and may be have a TV Tuner if necessary.
Low Profile and Beauty are not necessary for a HTPC. If u have the exra money to spend u can do so for Low Profile & Beauty, but they add nothing to the Home Theatre in the dark.
giddavr
HTPC: Asus P5VMDO Mobo, Intel Core2Duo 2.66GHz, 4GB DDR2 800MHz.RAM,
Nvidia GE Force 8600GT Grafix, Windows7ultimate, MPC Classic Player outputting to Panny AX200U, SPDIF signal to Onkyo505, PolkAudio Fronts & surrounds in 7.1 setup. 15" DIY Sub 150w. amp. from Parts Express USA. Wireless KB with Trackball. Samsung upconverting DVD player. 1350GB HDD.
very true. I also believe a remote is essential. If we are able to afford, then going in for a stunning cabinet is worthwhile.
I dont know if this is the correct thread to ask a question. I use my Vostro 1400 to connect to my tv (presently a 29 inch pana) through a dell accessory cable. I am able to output video using component cable but there is an spdif option in the accessory which accepts a round connection. i dont find an cable to connect to my av receiver. what cable should i buy.
