Buying fresh setup
GameMaster
Chennai
After breaking my head going for fresh setup and here is my choice any rating or reviews from you guys would be appreciated
HTP-RS32 |
becoz cant find any anywhere and mostly people dont talk about pioneer so I thought I ll start a thread here
Specs were quite average.
No Video upscaling/conversion to higher resolution.
No USB port
Speaker is of 8ohm which is +. But not sure it will support Bi-amping. Do you really want to go with this model for the high price tag Rs.40k.
No USB port
Speaker is of 8ohm. Not sure it will support Bi-amping. Do you really want to go with this model for the high price tag Rs.40k.
I am getting it for Rs. 33,000, whats Bi-amping how will it affect my performance becoz my next speakers is gonna be there only after another 6 or 7 years
I would pick it up for 33k (after auditioning with my favourite music type)***
***Providing it is not a display piece.
Why not a display piece? Is it becoz it would have run a lot?
Most electronic retailers like Reliance Digital, croma etc do not use the units properly. The play the speakers at higher volumes than it can handle, using poor quality sources and media.
not sore of rs32 however rs-52 have got good reviews and if i remmeber right.. one of our FM based out of mumbai has rs52 speaker setup which was imported through a dealer and have given a very positive feeback...
for 33 its seems to be a good deal.. but if you are strict on your budget.. looking around you might have more options..
Went to shop and what do they tell me RS-32 Out of stock buy the new one
rs-33
frustrated and bought it for 39k finally I have a tower speaker setup but dud the vsx-323 amp is not giving me a video output. SO waiting for the service to come by
