Can anybody suggest Streaming services best Dolby atmos and 4K movies
Dm me. Or just google it
Thanks........Got it configured.... it's great. Have been using Stremio for the past 3 years but always shied away from getting RD. Earlier I used to to download the media to watch on kodi with my HDD connected to my Nvidia shield. But now I don't need to download anything. Only thing is that some streams still keep buffering.
Does it buffer with RD as well? Could be due to your internet speed. I am on 320 Mbps plan and even 80Gb movies are butter smooth.
I am sure it would already had been mentioned here, but to reiterate Apple TV+ has the best quality in terms of picture and sound, However content is limited. I would rate Netflix, Disney(Hotstar) in the next spots. Amazon does provide high quality but I believe, they do compress the content a lot. Aha, Sun NXT, Jio, Sonyliv and other services are all mediocre. Although, Sony seems to be upping the game.
Netflix, prime, Sony Liv and Jio at my place. Netflix seems to be really good. Some of the content on Sony is also quite good.
As of now I use built in apps of the tv.
MaSh
Does it buffer with RD as well? This could be due to your internet speed. I am on 320 Mbps plan and even 80Gb movies are butter smooth.
Would you still be able to vouch for the above? Which player are you using? I was using the default Exo player; it used to stutter very frequently. I would reboot my Nvidia Shield TV to have stable streaming. After checking in the Redditt community, I understood that if the Vimu player is used as an external player, it helps to reduce the buffering significantly. I have installed the Vimu media player and am checking if the claims made by the users are correct.
Can confirm.
I am using RD with massive remux files and in my last 6 months of use, have never had a single stutter.
My setup is Kodi running with RD login on my XBOX > AVR > FANCY LED > LG TV.
I have a 300mbps connection btw.
I got new 4k TV and 4k home theatre. Can anybody suggest Streaming services that supports best Dolby atmos and 4K movies.
Hi, I know I am late to this party, but as per my experience below is the list of OTT channels best for 4k Dolby Atmos and Dolby Vision content.
1. Apple TV+ - not to be confused with Apple TV 4k, which is a streaming device (https://tv.apple.com/in). The very best streaming quality is available in India. Major Con: Not much content.
2. Netflix - It is best to go with this one as it has a very high number of titles/content. But you must subscribe to the highest plan for 4k UHD, i.e., Rs 649 monthly.
3. Disney Hotstar - You must subscribe to the Rs1499 plan to watch it in 4k.
4. Prime Video - Lesser quality compared to the above platforms but it is free with Amazon Prime membership and nothing can beat FREEEE;)🤣
Happy watching... Cheers!!!
