The Tweeter and Midrange should line up vertically to avoid the lobing effect.
One should avoid placing a two-way speaker horizontally as there will be a notch at the crossover point of the two drivers as shown in the diagram above when you listen to the speaker off-axis.
One should avoid placing a two-way speaker horizontally as there will be a notch at the crossover point of the two drivers as shown in the diagram above when you listen to the speaker off-axis. This is because when you are off-axis, you are closer to one driver and further away from the second driver. So the sound arrives to your ears from one driver earlier and from the second driver later. This off-axis time difference causes a phase shift at crossover point thus you get a notch as indicated in red, in the diagram above
Now let's take a floors standing speaker. Unless the floor standing speaker in not adjusted for correct height - the same holds true.
The path length between Left ear and left woofer is not the same as path length between left ear and left tweeter.
Also the conventional wisdom of keeping the tweeter at ear height is also wrong then - because that will lead to greater path between ear and woofer than ear and tweeter.
If that really makes a big difference then most floorstanders in the market should fail. Let us see why.
The diagrams that you have presented depicts the case when tweeters and woofers lie on horizontal plane, and hence cause perturbations to the sound front arriving at each ear - since the path length between Left woofer and left ear is different from the path length between Left tweeter and left ear.
If I were to put down my opinion on the original discussion, very few high end Floorstanders are properly designed, and are mainly intended for large rooms and not for small and medium rooms. You cannot put them against a back wall (wall behind the speakers) as the bass will boom (because floor standers have no bass adjustments for this half space condition), and if you mount them away from the back wall, you get back-wall bass cancellations (unless you put them 3 to 4 meters away from the back wall behind the speakers, which is hard to do in small or medium rooms). Either way, you are screwed.
I would say the bookshelf is by far the better solution and can be complemented nicely with a subwoofer crossed over at around 80Hz. This way you can put the main speakers against the back wall and not get too much of a bass boom (which can also be adjusted if possible) or the bookshelves can be placed about 1.2 meters or more away from the back wall (if the subwoofer is crossed over at around 80Hz) completely avoiding any back wall cancellations. This works well in most rooms of any size. The subwoofer can be optimally placed against the back wall (wall behind the speakers) and adjusted for optimum performance. Easy to successfully implement this kind of system in almost any sort of room.
The whole floor stander concept is considered rather weird by all the sensible loudspeaker design engineers I have known.
Richard Vandersteen, Peter Snell, Dave Wilson, Lawrence Dickie, Edgar Vilchur, Roy Allison, Henry Kloss, Ken Kantor, Kevin Voecks, Albert von Schwiekert, Mike Kelly (was he still at DBX when the made the Soundfield series?), J.W Magnepan, Gayle Martin Sanders, Jon Bau, Jon Dahlquist, Floyd Toole (NRC), etc...have all designed floor standers in their day even if the DQ10 and Quad ESL were not really traditional floorstanders.
The Wikipedia description BTW is specifically for the Canon Karat 770 (and other loudspeakers with integrated side mounted subwoofers like the NHT 3.3 and it's look-alikes).
By looking at these both pictures, don't you think condition is same. Only we are looking from different angles.
Consider Horizontal position- While watching from top you can see interfering lobes. But watching from side each driver lobe will look like same to the drivers in second picture. Because from that angle both drivers will in same plane, horizontal.
Same case applied for vertical position, second diagram - watching from side same amount of lobe interference could be seen. From side both driver are in different plane. So only direction of lobe interference visibility changed which is perpendicular to speaker position.
Don't you think problem persists in both the cases unless taken care by other factors like crossover, toe and distance of listener? IMO otherwise , before coming to listener, sound waves could have already undergone to inter-modulation, if any
active loudspeakers can even implement precision time alignment and phase alignment between the drivers for better accuracy.
