Can Raspberry Pi be used as network streamer
You need to configure moode to output audio through your connected dac.
Go to settings > audio > mdp options
click on edit button for mdp settings
Select your dac from the output device drop down and save.
This should output audio through usb
Thanks man. Will try it out in the morning. Any tips on getting Tidal Connect to work?
