Folks, I have a vague idea. Paradon my noob question, actually I was reading on active crossovers and stumbled upon the MiniDSP 2x4HD. It has 2 input sources / 4 outputs. Coaxial, Toslink and USB source inputs are also present.
Can we use this as a sound processor such that from Toslink input, to connect powered LCR + Sub (3.1) as outputs? One input source to all 4 outputs. This kind application is not mentioned in the "Application Notes" section of webpage. Also this would be easy to connect from TV which has option of Toslink, Coaxial as sound output.
Something like this can be a great solution as we get the flexibility to add Center channel and sub instead of just LR stereo when used with a 3.5mm stereo pin. My thinking is adding a good powered center channel significantly improves our TV / movies experience. Plus benefit of an active Sub for Bass. But then the decoding of center channel and sub should come to the Toslink signal. Did any one of you try this ? Any idea on how the sound quality would be assuming this works ?
Please let me know your thoughts on this.
