CD Player Speaker out to to amp device?
MohanK
I have a CD Player of my old Sony HT TZ215. I am thinking to use it to feed my Norge amp. The problem is the player has speaker outs only with 3 ohms. Any device can convert it to the input of amp? Any ideas?
The Front L + R would be the only way to pass audio signal to the NORGE and for that you will need to do some jumble with the wires connection etc....
The Volume of the player will need to be kept at 30% or max 45% to send appropriate signal to the Norge AMP.....this is a tricky affair and many are not successful in doing it.
Thank you, just realised another issue that there is a 2 channel stereo option in CDP, but low frequency goes to the subwoofer channel.
I found some converters in amazon around 500 - 1000rs.
