center and surround channel addition
parshwe
Gurgaon
Hi friends ,
I have Marantz sr5005 with Wharfedale 9.5 standing left right channel. Planing to buy center and surround channel which goes great with this set up.
Please suggest which wharfedale setup i should finalize.
In center I found 10.cs good but seller recommending 9 series.
For surround 10.dfs heard but not able to decide. Is 10.2 better for surround.
Please also mention approx pricing of the recommended solution.
Br//
Pant
Hi friends ,
Br//
Pant
Since you have diamond 9.5, it is better to go with 9 series center...Reg the surrounds 10 dfs should do the job...
9 being an old series, you should get good discounts...
Thanks a lot for the suggestion.
I have not yet taken demo of 9 series. I will compare both of them at the home setup.
Any other suggestions are also welcome.
Br // pant
Br // pant
You haven't mentioned your budget...
Consider Sonodyne Rears Dipoles for around 12K if budget is a constraint...
If not consider Sonodyne Avant 150 around 18K....
hi,
I have thought of approx 30K for the center and surround togather.
Is there any impact using two different speaker system for the HTS.
What could be possible pro and cons of two diff speakers in one 5.1
channel setup
Pant
hi,
channel setup
Pant
If you use Left, Center & Right from the same series & surrounds from other brands, it will not be a problem...
However, if you plan to have a diff brand center speaker to your Left & right, then it might not cause uniformity....
Ok. That means in my setup I have to go for either 9 or 10 series of wharfedale. But surround I can choos from other vendor as well. Only thing is esthetic should be same for both.
. Is there any other good brands I should check in my 15k budget for surround?
Regards Pant
Regards Pant
For center 9 series better..If not 10 series....
For other brands you can try Polk / PSB / Tannoy / Paradigm / Mission....
