Clarification required - Samsung HT-TZ315
dawg55555
Hi all,
I am interested in considering the Samsung HT-TZ315. Features and price seem very good value for money. This system sells for Rs.16500.
HT-TZ315 home theatre systems - home theatre SAMSUNG
However on the Samsung India site, it shows that the 315 does not have Dolby Digital, which I find really ludicrous. DD is almost default on all systems these days. I called Samsung india and they told me that it does not have DD.
However I would like to clarify from somebody who owns the 315. Could you confirm if it supports DD 5.1? Many thanks !
Hi all,
Dolby Digital is not supported. majority of the movies in india are released in DD format only... hecne DD decoder is must..
why dont you have a look at Onkyo HTS 3100. for additional 2K you will get a more reliable HTiB
Thanks,
Prakash
Have attached the relevant page from the user manual (same for 6 models)
As you can see, DD (15) is clearly shown as available.
BTW, BT (8) is not available for 3 models and indicated accordingly.
I've downloaded the manual and yes it mentions Dolby Digital.
But I find a lot of strange things ......:(:o
1) 1000 W Rms and main unit weighs only 3.5 KG!!!
2) ElectricalPower consumption is only 80 W
I CANNOT PUT IT IN WORDS BUT I THINK IT IS HAVIING BEST POWER/WEIGHT RATIO!!!
NOW
1) I am not able to locate THD figures
2) Speaker impendence is 3 ohms -- first I've seen
3) Subwoofer size not able to locate
4) Subwoofer is active or passive?? Not able to locate
Fellow audio lovers please can you add something??
My advise --- NOOO!!!
NOW
1/ Usually THD is in the range of 8 - 12% for HTiB systems (.08 - .12)
2/ This surprises me quite a bit. Pls. double check as they seem very inefficient
3/ 6 inch
4/ Passive
Hi Guys,
I am Using the Sammy HT-TZ315 with Panny 42X10D Plasma. When I am playing the DVD movie using this player, on screen it is showing 576P. Is there any setting I made to get it upscale to 1080P? by the way Panny X10 is HD Ready Plasma.
Please advice me on this.
Satya.
