Clarity not Loudness
sushantsah
delhi
I have a room 10.25 x 18, where i want to put a decent hometheater.
I am looking for games, movies - not too loud, as don't want to disturb neighbors, but want crystal clear effects, voice and music.
Please suggest 2-3 AV in range 30 to 50 K (5.1 / 7.1 / atmos Setup)
thanks
Entry level 5.1 HT systems from Yamaha/Pioneer/onkyo would be available within that budget.
Carry your music and auditon and decide..
Just seen on Reliance digital website...YHT196 for 28k add 999 and get a blu ray player or dvd player
Is that HTIB ?
I am looking for assembling over a time...
put a sealed sub
no ported
half your problems solved
guys like me will not put a sub at all
what is sealed sub and no ported ???
willnot put sub at all. what the pros and con
my usage is 40% ps3/4games, 40% eng movies, 20% youtube/music/etc
reg
It is not HTiB but entry level separate systems.....audition and decide..
any suggestions for speakers for 5.1/7.1/atmos (is enough content available)
5.1 that can be upgraded to 7.1 or atmos
I saw some speakers mentioned in the forum cost a fortune @lol
Please suggest speakers for 5.1 decent not too bad not too expensive,
so i can get 5.1 (with active sub), or passive is good for less budget ????
thanks a ton
Pioneer AJ series are well acclaimed budget speakers with good sound quality and review comments.
https://pioneer-india.in/product/aj-5235xt/
You can buy them one by one like fronts first, center next and rears at the end or all as a package. (your choice) :)
Looks decent in 70000K, any more options in 50 to 70 K, for similar / better setup
So my budget will be around now 40 to 60 K for av
and 50 to 70 K for speakers
reg
reg
You can get Pioneer AJ 5.1 setup for 58K from MZ audio in Mumbai, ask them i think they can courier you that as well. I had asked for courier to Pune they agreed in the same price mentioned they will use FedEX
