@gourav @jbkar @OM_2K19
Completely agree with your statements. That's the reason, I was lucky to ask them to show a Scene from the same movie which comes before the Fight Sequence (the book discovery) where they speak in a much lower voice. I felt QA3090ci weak in that regard.
However, turned out for the best for me as I got Dali's. Decided to wait for Oberon Vokal.
FM Pro's,
After checking with almost all Dealers in Bengaluru, few dealers in Mumbai & NCR, got to know that prices for Denon X1600 had sky-rocketed.
But took a conscious call and went for the best possible deal and
booked Denon X2700H
. @Bizi05 has been instrumental in helping me get to this decision. Thank You very much
@Bizi05 for the same.
@Prodigy You gave the best AVR advice in the very first comment
and it took me countless hours to finally land on the same AVR you recommended.
X2700H from X550BT (I' must say I'm very satisfied with the decision as I'd be able to use 4K@120HZ using PS5(yet to buy - no stock
) and Samsung Frame TV which too supports 4K@120Hz . You all saved me from making a very bad call in the beginning by going for X550BT).
I'm now researching wrt getting Speaker Cables while the AVR arrives and I need your help in this regard too.
I understand that it's better to go with 12 or 14 AWG OFC Speaker Cables. I'm a little confused about which size of Cable to get and from where.
The Distance from AVR to Left and AVR to Right is 1 Meter. I have attached the picture of the TV Stand (2 Meter length).
So considering the instances when I may have to take the AVR out to attach few things, I'm considering 1 extra meter for each side to be safe.
Is getting 8 Meter Speaker wires to accommodate my AVR with L+R a right assumption or I'm missing something?
i.e (2Meter X 2 = 4Meter per Channel = 8 Meters)
On the other note, I found that AmazonBasics 14 AWG Cables are OOS. I also heard that these are copper coated wires with Aluminium inside. (Not sure how true it is)
I also saw few threads, where FM's have bought 2.5 sqmm i.e 14AWG wires from Finolex/Polycap and used Spade plugs/Banana Plugs to terminate as a DIY project to get high quality cables at good price.
I also came across below one from AudioCrafts which is a 12 AWG Cable and 8 Meters would cost around 3200 INR :
theaudiocrafts.com
Can you please suggest, for my setup shown in the image, what should be the best way to get a good quality Speaker Cable?
