Had been eyeing Class A amps for sometime, but could not find anything in my budget.
Then managed to procure a well received ADCOM 2-channel vintage car audio amplifier.
Model GFA-4302: Looks like a dual mono design as it has separate gain pot for each channel.
Class A operation to the MosFets with all gain stages up to the outputs in pure, single ended (asymmetric) class A
30 watts per channel into 4 ohms (100 watts mono)
Frequency response: 0Hz to 50kHz
Signal to noise ratio: 100dB
Channel separation: 90dB
Damping factor: 350
Input sensitivity: 400mV to 2V
Associated Equipment:
A 220 to 14 volt SMPS based inverter
Laptop with Plex server
DAC-cum-preamp: Chromecast Audio
Chromecast Audio analogue output connected directly to the ADCOM amp
Heavily modded Infinity Reference 425 2-way bookshelf speakers
Basic MX 3.5 mm to RCA cable between the Chromecast and the amp
16 awg OFC multistrand speaker cable
Handmade stand using tree trunks
Pitfalls:
Boxy untreated room, 25 dollar DAC, wireless streaming, average quality interconnect
Listening:
As the amp was unused for almost 5/6 years, it took almost 4 hours of run to open up and then it was just mellifluous.
One word 'goosebumps', incredible control over the drivers, absolutely lush midrange, excellent integration to the lows (though does not go very deep but clean and taut), reasonably detailed and smooth highs, absolutely non fatiguing.
Spot on imaging and a wide stage.
Did a long listening session of almost 20 hours with 2 short breaks.
Listened to a wide range of music.
NAD3020 has gone into cold storage
Links:
https://goo.gl/photos/9dpFJ4R35sNk8ntG9
https://goo.gl/photos/YCAsUTv1meCVpJRA6
Damping factor: 350
Pitfalls:
Listening:
Links:
