Conduits for power cables
hifisound
Hi all,
I need to move the electrical connections from current location to some other place on the wall. Since now it can't be done internally, I will have to do it on the wall surface .
So any indian brands which have good designer cable conduits. The usual PVC ones available in electrical shops are not good looking. One option is to ask carpenter to put a 6" panel. But I am also looking for ready made options...
Thanks,
Hifisound
MK Electricals have ready made conduits of the ~4 inches wide. I have seen them in Rajshri Electricals (a dealer for Anchor, MK, Clipsal etc) in BVK Iyengar Road, Bangalore. It is expensive and you will have to buy a full length of around 10 ft.
They look something like this:
