Creating a DVD with DD and DTS sound tracks
prakasse
bangalore
I have used DVDFab and extracted the songs of many Tamil and Hindi dvd's.
All these have both DD and DTS Sound tracks.
Now i would like to merge these titles and create a songs dvd that has both DD and DTS tracks. When i use Nero vision only one audio track is getting selected and i have no choice to select DD or DTS or both.
Any pointers would be appreciated. Are there any softwares for these?
Thanks,
Prakash.
It extracted from DVDfab,then write them as DATA DVD in nero
(both Video_ts & audio_ts folders)
DVDp shld play as mine.
Thnx.
But i want to have more than one film somgs in the dvd. For eg i need to combine roja, taal, dil se in to one single song dvd. in this case i will have 3 audit_ts and 3 video_ts folders right?
Ok,
In DVDfab,there is merge opt.,try that ,write on RW DVD & check.
Secondly Nero 7 can do the same for you.
You need to select DVD-vid in Nero7, select vid Q highest(8000kpb), set aud opt to 5.1DD & let nero handle.
It works for me,but Nero does reencoding & may be some change than original,but DD5.1 ch.
