Hello Yuvraj,
This is in response to your post
here.
DDTS-100 is serving you as a decoder + preset equalizer (movie, music, cinema) when you use its 5.1CH outputs.
It is serving you only as a preset equalizer if you use stereo output.
In either case, with present day recordings, you need much more to get that amazing sound which the very expensive systems have.
Its called post processing. It brings out all the details present in the recording that you were unable to hear before and a few things more such as bass management, volume levelling and so on.
Post processing is a general term. It is more popularly called auto calibration or Aydyssey.
With my product, I have simplified things for the end user. He can just connect stereo input, which can either be Analog, SPDIF Optical or SPDIF Co-axial, connect the speakers, adjust the master volume and enjoy either stereo sound or surround sound. You don't need to worry about decoder, post processor, equalizer. Its all taken care, internally and intelligently!
My product, however, does not offer 5.1/7.1CH. Only 2.1CH is enough to Surround you!
I hope that I have clarified your doubts.
Ravindra.
