music4mhell
Wow yes that would be amazingly useful. Thanks! Sending you a PM
Welcome, any FM can come and enjoy my speakers, headphones with Mojo on any weekends hyeah::yahoo:
For lush mid range and sweet highs, a tube can do wonders which no DAC can do, even expensive DACs. I may be wrong but that's what i think. I felt so after getting Tube Buffer in the chain. Yaqin CD3 is the name.
Sent from my SM-N750 using Tapatalk
Hi,One question regarding the Swara. Looking at this diagram of how it operates
http://acousticportrait.com/images/Lge/m2rpi_an.jpg
That means that like Auro if there is an issue with the dac connecting to the wifi for some reason, then I will need to have the dac and speakers close enough to the router. That won't work for me.
Also just to clarify to this has no typical USB, coax, or optical inputs in case wifi is erratic or conjested?
Why the Swara Pi DAC could not detect wifi in my home, is still a mystery to me. I initially thought its pi 2 inside which does not come with built in wifi. In fact auto detection of Pi version shows it's Pi 2 and not Pi 3. This is strange as Siva told it's Pi 3 and he tested the built in wifi feature and it worked for him. My modem and pi is placed close enough and a lan cable can directly be connected. Hence non working built in wifi was not a big deal for me. But for you if you really need wifi, you can always but a wifi adapter which is about Rs 150 on Amazon.
A operational issue, I face, which I do not know if is particular to this Pi, is that Rune audio doe not detect Pi streamer for first 5 minutes after bootup. Siva confirmed he faced this problem too.
Navigation to music though Rune is not very friendly for people who used Foobar so long. Placement of "back" button on top left is an inconvenience for going back to root folder every time you need to browse. The common tendency of back button of phone will get you out of Rune application.
Auro
Sent from my Mi 4i using Tapatalk
Thanks for clarifying on the wifi issue. Connecting the wifi adapter if it works then it good. I certainly can't have my router and audio setup near each other in my house. Were you trying to connect on 2.4Ghz or 5Ghz?
I am ok with Rune so that shouldn't be a problem. However the lack of usb, coax, optical inputs in addition to the streaming is a bit of a problem.
Kindly note, "lack of usb, coaxial, optical" ... Is not a correct statement. Just curious what other digital forms of input ports will we be left with if we leave all of these three. Obviously there is usb input ? But i agree lack of optical and coaxial or sdif may be your concern. But remember the streamer is Pi based. Kindly look for Thyaga DAC if you need all three digital input ports, buts that's 3 times costlier and of different class altogether.
For Wifi, Siva email me and called me. He thinks there must be some mistake in my wifi config, or the os on the pi needs upgrade. He offered to visit my home to fix that. He mentions he tested wifi feature and he is sure the built in wifi shod just work. Now how many commercial players offers a home visit to understand customer's problems with their product, even after knowing it's not a big deal and is a quick fix with 150 rupees usb adaptor.? I highly recommend Acoustic Portrait Swara )Pi based dac. Just my opinion though
Auro
