Nairrk
Dangbei has launched a new high-end 4K projector called F7 Pro in the Chinese market. The projector is priced at 7,999 yuan ($1126) and it is now available for purchase on JD.com. You can use coupons to bring the price down to 7,439 yuan ($1047). Let’s check out its key specs.
Dangbei F7 Pro uses the latest three-color laser technology that eliminates speckling and colored edges commonly found in traditional laser projectors, offering improved color saturation, brightness, and comfort. It can project a screen size equivalent to eight 65-inch TVs combined.
It supports the MT9679 chip, AI OS 5.0, and features like a 360-degree adjustable gimbal, AI voice assistant, and self-calibrating picture adjustments, making the experience seamless and user-friendly.
The F7 Pro boasts 3600 lumens brightness (according to CVIA standards), ensuring a clear picture even in bright settings. It covers 110% of the BT.2020 color gamut, achieving professional-grade color accuracy with △E<1, making the colors vibrant and lifelike.
It also has TUV low blue light certification to reduce eye strain, along with zero harmful blue light, making it ideal for prolonged viewing. The projector features a Qualas 22 laser engine, boosting performance by 20%, and supports 10-bit color depth with 10.7 billion colors for enhanced image realism.
The F7 Pro features 4GB RAM and 64GB ROM for quick app installation, multitasking, and smooth video playback. It supports Dolby Audio DTS with a 750cc sound chamber for powerful low-frequency sound down to 45Hz. For connectivity, it includes Wi-Fi 6, HDMI 2.1, USB 3.0, and Bluetooth 5.2, making it compatible with gaming consoles, PCs, and streaming devices.
The projector includes AI-powered features like multiple screen interaction modes, smart whiteboard writing, and gesture-based navigation for smartphone-like operation. The remote uses light-pointing technology for precise control. It also features advanced cooling and heat dissipation, boosting durability and performance.
The projector supports AirPlay, Huawei Cast+, and Windows Miracast, ensuring easy screen mirroring from various devices. The packaging includes a custom carrying case as well.
News credit: Gizmochina
