Hello All,
I am looking for a decent 2.0 setup that can be scaled to 2.1 or 5.1(preferably but not a necessity) in future. It will be used for both music(mostly) and movies and the room is around 15x20 ft.
Music will be mostly digitally streamed from Spotify/Amazon Music. I will prefer floor standings over a bookshelf.
Praveen
Hi Bro,
Since you specifically say floor standers, I'd suggest either the PSB Alpha T20s - one of the best all-round, VFM speakers I have ever heard - or the Emotiva T0+.
The Alphas have also got a pretty decent +-3dB claimed freq on-axis down to the 40s if I am not wrong...
Which should work wonders in your room, though my experience of listening was in a bigger room and it was even then mind-blowing.
These speakers will not fail you.
They will also give you enough time to budget for a great sub. (Speakers that go low will never replace a sub, but you can live with them longer...)
Then, pick up the best AVR/best integrated amp (AVR: Up to 5 channels, pre-owned or base models; IA will suit you well right now, but you will have to spend on channels later) with what is left from the budget.
I'd suggest stretch budget a bit, and pick up a pre-owned AVR which you think will serve you well for two years at the least...
If it is music
mostly as you have mentioned, then you will have to live with two channels for a few months, with an integrated amp....
Then just a matching Centre from PSB + cheap AVR or processor, and you are sorted.
5.1, and all the other farkle, you can add once you have experienced the main course in your room. If you go stereo amp now, you will need an AVR for this later anyway...
So, decide on what really you want... an AVR for future channels for movies, or a good amp for your stereo requirements now, and another spend on an AVR when you need to increase channels...
In your case, if have to go out on limb (since you want both 5.0 sometime and a good pair of FS right now), I'd suggest go with an IA for now, and then sub, and when you are ready, a pre-owned processor + additional channels....
An alternative speaker choice for the budget would be the Emotiva T0+, which will leave you with a slightly lesser budget for the power part..., but they are great FS speakers nonetheless, despite the Indian going rate...
Since you are in Pune, you should be able to find an audition for both...
Regards and best
