Klipsch SPL-120 12” subwoofer@edjamesx
@Yelamanchili manohar
@k-pad
@caspian1985
@sud98
@Phani24
Please recommend a 12inch sub in 1 lac budget. Preferably ported.
AVR denon x3800h
Monitor Audio bronze 500 and C150 with bronze 50 surrounds.
Also suggest atmos speakers for mounting on the ceiling (not inside the ceiling). Budget 50k for 2 pairs
I compared SVS PB-2000 with Ascendo SV-12 in my room and preferred Ascendo. It has very good output between 40-80Hz and with proper placement extends down to 20Hz.Is SVS PB 2000 for 90k worth?
But SVS service is really good i have heard. And with 5 years warranty.I compared SVS PB-2000 with Ascendo SV-12 in my room and preferred Ascendo. It has very good output between 40-80Hz and with proper placement extends down to 20Hz.
My recommendations for 12” ported are Ascendo, XTZ and Rhythmik.
Will be out of budgetMonolith 15 sub will be a beast
Is it a used one? . I think new one costs > 1.1 Lakhs. If its used one then try getting it for 70 to 75k. It's good sub woofer at this price.Is SVS PB 2000 for 90k worth?
It's a new sub with 5 years warranty. I am more inclinded towards SVS as they have good support in Delhi area which is near by.Is it a used one? . I think new one costs > 1.1 Lakhs. If its used one then try getting it for 70 to 75k. It's good sub woofer at this price.
Othe Subs to consider , might cost you more than >=1 lakh
REL HT/1205
XTZ 12" Sub
Rythemic 12" sub
If possible try to audition these subs yourself and decide best.
PB2000 pro & PB2000 have same specs but Pro model has more customization and Eq.I am also looking into PB2000 pro for around 1.15. Is it worth over Pb2000 ?
My bad, had no idea it was so much overpriced in IndiaWill be out of budget![]()
what price you got pb2000 proFinally pulled the trigger on SVS PB2000 pro and polk OWM3 for atmos.
Thank you everyone for the suggestions.
Only thing left is Projector.
Preferably in 2 lakhs budget.![]()
1.15 lakhwhat price you got pb2000 pro
They are best in my area atm. Will finalise thenTo me its a bit unbelievable that you can get all that done for 10k. But if you are getting someone for that low a price and you are sure they are honest and capable, please go for it.
If they can do all of that at that price, please take it, eyes shut.Should i opt for expert consultancy for HT installments and calibration for 10k?
They will finalise the speaker placements and help the electrician with the wiring..
Mount atmos and surround speakers.
Callibrate the system.
Mount projector and screen.
DoneIf they can do all of that at that price, please take it, eyes shut.
Epson TW9400Only thing left is Projector.
Yes. It's on top of my list.Epson TW9400
