Now if you could guide me which would work better with AVR Pioneer VSX 934? 7.1 setup.
Amplification
› Channels: 7
› Amplification Type: Direct Energy
› 160 W/ch (6 ohms, 1 kHz, THD 10 %, 1ch Driven)
› 135 W/ch (6 ohms, 1 kHz, THD 1.0 %, 1ch Driven)
SPEAKERS floor standing :
Taga TAV 806F --
Design | Floorstanding, 3-way
4 drivers
Bi-wiring, bi-amp
TLIE enclosure
Crossover points: 600Hz 4kHz |
Power handling | 20 - 180W (recommended amplifier power)
135W RMS |
Frequency response | 30Hz - 25kHz |
Bassreflex | Front single |
Impedance | 6ohm |
Sensitivity | 89dB |
High-frequency driver | 25 mm (1"), TWG |
Midrange driver | 133 mm (5.25") |
Bass driver | 2 x 203 mm (8") |
Dimensions (H x W x D) | 108 x 24.5 x 31.2 cm (excl. spikes) |
Weight | 18.4 kg / pc. |
OR
Taga TAV 606F SE.--
4 drivers
Bi-wiring, bi-amp
TLIE enclosure
Crossover points: 650Hz, 4.5kHz |
Power handling | 20 - 150W (recommended amplifier power)
110W RMS |
Frequency response | 36Hz - 25kHz |
Impedance | 6ohm |
Sensitivity | 91dB |
Midrange driver | 133 mm (5.25”) |
Bass driver | 2 x 165 mm (6.5”) |
Dimensions (H x W x D) | 98 x 23 x 25 cm (excl. spikes) |
Weight | 15.1 kg / pc. |
I was leaning towards 806F and VSX934, but 91db sensitivity (vs 89db) makes me think of 606F SE., as less watt required for same loudness, and anyway putting in a separate subwoofer. Am I correct?
Should I go for Pioneer LX-304 9.2 setup., For 7.2 amplification and maybe 2 more later??
AMPLIFICATION
› Channels: 9
› 185 W/ch (6 ohms, 1 kHz, THD 10 %, 1ch Driven)
› 170 W/ch (8 ohms,1 kHz, THD 1 %, 1ch Driven IEC)
