I am using this Origin Dehumidifier at my residence in MumbaiHi, any advice on ,if a dehumidifier in a costal ( high humidity) city ( Bombay) is a good idea towards protecting our equipment .
Yes I bought it for the room in which equipment is kept. It requires draining after 2 sessions. It is very effective.Did you get it specifically for your equipment ? How often do you drain it?
Thanks. It's a toss up between origin and the sharp ( which has a purifier built in- HEPA).Yes I bought it for the room in which equipment is kept. It requires draining after 2 sessions. It is very effective.
I do move it around the house as humidity tends to be very high in Mumbai .
That's an option. ThanksI use my air conditioner even if the temperature is cool because it achieves the same thing as a dehumidifier. It's an inverter model so low electricity consumption. I also keep an eye on indoor humidity levels throughout the day and ensure it stays b/w 50 and 70%. Without keeping the windows closed and turning on the AC, it goes up to 80-85. That leads to mold and condensation everywhere.
Correcting myself, the model I bought was Origin Novita Dehumidifier ND 838.Did you get it specifically for your equipment ? How often do you drain it?
Thank you. I might be tempted by the Sharp, as a friend has it and recommends it highly. Mutually known to Rikhav too.Correcting myself, the model I bought was Origin Novita Dehumidifier ND 838.
Which sharp model are you planning to buy?Thank you. I might be tempted by the Sharp, as a friend has it and recommends it highly. Mutually known to Rikhav too.
DW- J20FM-W.Which sharp model are you planning to buy?
I use the SHARP DW- J20 FA It's a lovely machine i have been using it for 2 years now , also i put it on the air purifier mode when I'm in the room and the A/c is switched on. I use the ORIGIN- ND 328's in the bedrooms . I stay close to the sea and these machines have worked fine for me.DW- J20FM-W.
Thanks Anand. That's great info.I use the SHARP DW- J20 FA It's a lovely machine i have been using it for 2 years now , also i put it on the air purifier mode when I'm in the room and the A/c is switched on. I use the ORIGIN- ND 328's in the bedrooms . I stay close to the sea and these machines have worked fine for me.
Cheers!
Anand
My take on it is that if I am putting some money down on a dehumidifier, might as well get the purifier option ,a good addition in our cities and if its a HEPA, excellent.I got the Origin dehumidifier since couple of months, its used mostly in the rains & sometimes summer.
Very happy with it.
Cheers..
Makes sense, our city needs dehumidifier in the rains for sure. So get what suits you.My take on it is that if I am putting some money down on a dehumidifier, might as well get the purifier option ,a good addition in our cities and if its a HEPA, excellent.
They advertise in a rather funny way. Not that we have any doubt it does not work wellGot my Sharp delivered today. It brought down the 90% humidity in my room to the set 50% ( adjustable) in about 45 minutes. Fairly silent. Overall I am satisfied with the product. Hopefully it will protect my equipment from damage due to moisture .
