Denon 1100w or Marantz 1605
viraj
Chennai
I have this confusion - Should I buy Denon 1100w or go for Marantz 1605, which is twice as costly. My room is small (17*20) and I feel both the Receivers would be good. I am planning to get Zensor 3. I am planning to get either one of these receivers from USA as the refurbished ones are half the price there (a4less).
Negative aspects of Denon 1100w (price:Rs.15580):
1. I read that if you disconnect, then you need to configure it again afresh.
2. Size is bigger over Marantz 1605.
Negative aspects of Marantz 1605(price:Rs.29045):
1. Price
I need to buy a step down transformer for these which would cost around 5000 rupees since the receiver is from USA. Any advice?
