Denon 1311, which 5.1 speakers to use? Polk Audio rm6750 or Boston Acoustics xs5.1 or
Re: Denon 1311, which 5.1 speakers to use? Polk Audio rm6750 or Boston Acoustics xs5.
As a dealer at Vizag we have been selling all the models of Denon since
2004. Rm 6750 will go well with 1311. We have also been suggesting
RM 6750 or Paradigm Cinema 70 and Cinema 90 for all the 1500 series Denon
amps and all of them sounded very good. 1311 which is a new entry last
year also is a good amp for the beginners in Hi-Fi. In case you do not want
to upgrade in the near future we suggest you to go for 1611 with Paradigm
Cinema 90We are still fighting with the supplier of Paradigm to resort to the old prices of Rs.33000/- and 37000/- for Paradigm Cinema 70 and 90
linnhifi
1311 with True Master HD (MRP Rs.24900/- itself is a quite good amp. with
audio processing over HDMI and also upgradable to 7.1 Ch by adding two
more powered speakers throough the amps preout provided. Yamaha 367 is
also a good basic amp MRP.21000/- do not provide audio processing through
HDMI. In any case instead of buying in the gray market we better argue
for more discount from the dealers.
linnhifi
How about the Energy speakers , CF30 Pkg (5.1) . looks like a good deal at around 60k in Mumbai :yahoo:
Sweet ... Congrats ...!!
Do put up reviews n feedback for the same mate ;-)
Enjoy the new home cinema experience
Hey all,
got denon 1311 + paradigm ct 90 installed at my place. Sounds awesome with BR and Music.
But there is an issue, a big issue actually, I've got a TATASKY HD+ installed at my place, all the connections go through denon on HDMI., Now the issue is that audio is coming half a second earlier and then the visual. Anybody has anyidea, how to solve it? How can i avoid this lag in the visual??
plus some basic questions, based on your experience if you can guide,
my room size is 13x12,
1) what should i set the cross-over frequency for all my speakers?
2) what should be the set-up in Channel level for each speaker?
Your replies will help :)
bhavesh.
try set cross over freq to 80hz & all channel level to 0dB
Try setting up audio delay for the audio delay problem. shud be there in manual setup
