Dear All,
I am replacing the Denon 1908 in my family room (this unit will move to my bedroom).
Reasons for change - (1) not enough HDMI connections (2) want 2 zone capability to play speakers on my terrace also and (3) want Apple Airplay capability since I have set up an Airplay network.
At the least, I will want Denon 1912 (same power as before, but with above 3 added advantages.)
However, should I consider:
Marantz 5006
1. More power - 100w v 90w per channel (into 8 ohms). My family room, dining room and living room is one large contiguous area - maybe more power will help? I am running Wharfedale floor standing front speakers at the moment.
2. Better at music. Is this true? Is Marantz better at music? I am playing a lot of music now since I set up an Apple mac mini as my HTPC and loaded ITunes on it and all my CDs in full Apple lossless codec.
Marantz 6006
1. Still more power - 110w per channel
2. Marantz literature says it has - "high grade audio components". What does this mean in real terms?
3. Video scaling and de-interlacing via ADV8002 chip. Does this really help in any way. I am using a Panasonic 50" VT20 TV and Tata Sky HD. Will the non-HD channels look better with the Marantz 6006 doing the scaling?
Any other - Denon 2312?
I will be travelling to Singapore in about 10 days time and had planned to buy from there. Is it a good idea? Or should I buy from India with warranty?
Thanks in advance.
Marantz 5006
Marantz 6006
Thanks in advance.
