denon avr 1311 bluetooth
huntersingh
knp
hi
i have a denon avr 1311
but it dont have bluetooth, and i want to listen songs from my phones via bluetooth ?
how can do it ?
1311 is not enabled with bluetooth as a matter of fact no AVR has bluetooth except may be at high end but surely most of the AVRs have airplay but 1311 is basic so it wont have airplay.
You can use you android/ios device to play the songs o your AVR wirelessly using the common wifi connection. for that you will need to upgrade your current AVR.
