Denon AVR X550BT questions
nk_gautam
New Delhi, India
Hello everyone, I have just bought a Denon avr x550bt + Taga Harmony 606 V3. It was installed yesterday. I have 2 concerns:
1. When i tried to play FLAC files stored in my 16gb usb, nothing was happening. No folder or files were shown. So, i thought either I m using a 16gb usb which is not supported by the amp (It might support low capacity usb's), or i need to update the firmware? I m still confused.
2. As it is not a wifi model, how do i update its firmware from a file? I will be really grateful if someone can provide me with a link to download the update file.
The denon model is this support flac file over usb? check the specs before you play it.. you can try some wav file also.
