Surender Kumar
I am confused between denonX1400 & X2400. My budget for speakers is around 60k. Will used for movies and music.
the x2400 is a better mid range denon avr. I got the x2300(prevous edition) & it has amble power & decent features.I am confused between denonX1400 & X2400. My budget for speakers is around 60k. Will used for movies and music.
Thanks for your feedback.There is no much difference between those models except 15W difference.Both are 7 Channel .if you want 4k upscaling and component video in and out you should prefer 2400H.May be slightly better built quality which includes better powersupply( you did not mention about your shortlisted speaker and preference if any and the room size).May be couple Hdmi inputs will be extra,most of the cases any AVR which has 5 + hdmi inputs it will be of no use for most of us imo.
Considering 2400H has 2 nos of hdmi out which is an additional feature which can be used for if you have monitor/TV as well projector.Add on to that 2400H has serial port for customised installation which most of us not using at all.
Plan your speaker and finalize the budget.
Between those 2Avr model price difference will be around 10- 15k imo.
Take feedback from FM. There are couple of FM who already own these models I believe.
Atb
I will be helpful id you tell me about some good budget speakers. My use will mostly be movies ans muaic. I dont like to listen loud music. So will want to have good thump and bass at low volumes. My room size is about around 140 sq. Ft.There is no much difference between those models except 15W difference.Both are 7 Channel .if you want 4k upscaling and component video in and out you should prefer 2400H.May be slightly better built quality which includes better powersupply( you did not mention about your shortlisted speaker and preference if any and the room size).May be couple Hdmi inputs will be extra,most of the cases any AVR which has 5 + hdmi inputs it will be of no use for most of us imo.
Atb
Will it require subwooferYou can go for Boston Acoustics CS260 package which would be best at its class.
https://www.amazon.in/Boston-Acoust...0_FMwebp_QL65&keywords=boston+acoustics+cs260
