john_k_antony
Friends,
The DIY bug has bitten me pretty badly . I was in the lookout for setting up a dedicated stereo setup for my HT room. I just wanted your opinion and feasibility of doing a DIY speaker system and a SS power amp to be used in the dedicated room.
Little bit on the room.
Dimension - 24'x15.7'x9'. The height is actually 10', but I will be doing a 1' false ceiling with Auntone Subtex ceiling tiles thus reducing the effective height of the room to 1'.
Acoustics - Will treat the walls and ceiling using Anutone boards and acoustic panels. Will also be doing corner bass traps.
Now I want a stereo system that will fill the above room (~375 sqft) with loud clear music. I was planning to get high efficiency single driver speakers from Zu and use a SET tube amp.
I will be using a TT and CDP with the setup as sources. I am planning to get a vintage DUAL 1019 restored by Mr Kuruvila Jacob . CDP is Oppo 105.
Now that DIY has gotten into my head, I am "dreaming" of building a system to satisfy my requirements. I want to build a 3 way speaker system and mono block SS power amp. I am planning to buy the following equipment for their sheer quality, musical performance and VFM
1. Lyrita Audio Phono Pre
2. Lyrita Audion DHT Pre
Now for the speakers, I want to build a 3 way system using all scan speak drivers. I saw one build here - Jensen-1071. Looks pretty impressive and have good reviews. This is an expensive project to build, but looks promising. I am choosing scan speak drivers as I was thoroughly impressed with their performance in the Acoustic Portrait speaker builds. This is other option - The Madisound Speaker Store. The performance number looks sweet :licklips: - Frequency response of 25Hz-40kHz, +/-1dB, and a sensitivity of 92dB/2.83V/m. Review of the speakers - SoundStageXtreme.com | UltraAudio.com | PBN Audio Scan-Speak B741 Loudspeakers
What would be the customs duty for importing speaker components like drivers and cross over electronics ?
How much money should I set aside for building speaker cabinet using MDF/Ply with veneer finish with material and labor cost for a tall 3 way FS?
I am scouting for the DIY mono block power amp projects. Came across one here - High End Audio MOSFET Amplifiers - Amplifier Modules - DIY Amp Modules - DIY Audio - Amp Kit. This looks good, but don't have much reviews. I am looking for a 200W/ch mono blocks.
Well, I am setting aside the following budget
1. Speaker build - 1.5-2L / pair (all inclusive, cabinet, X-over, drivers etc)
2. Power mono blocks (200W/ch) - 1L / pair (again all inclusive with cabinets, transformers, heat sinks etc).
Well the above budget is the MAX cap. I will be very glad if I can get some kits that cost significantly lesser and give the big sound stage to fill the 375 sft room.
What do you guys think about this? Am I going completely insane or does this make sense to build some thing of your own?
Do you guys feel the system I am planning to build can fill a 375 sft room with enough punch/crunch and quality sound?
Thanks,
John.
Thanks,
John.
